window motor replacement - FirebirdV6.com/CamaroV6.com Message Board
  • window motor replacement
    ok so I was following the window motor replacement guide and i found, my driver window motor is not held in by rivets but with a screw/nut deal that will not budge loose. not to mention, there isn't a whole lot of room for a lot of tools either...any ideas?
    Re: window motor replacement
    That means its already been replaced.
    Its tough to reach and hard to do it will test your F body love.
    You may need to do a whole bunch of small turns with pliers.
      i ended up getting it, however, the person who replaced it previously must have found a way not to drill through the fiberglass & put the head of the screw on the inside part of the door where you have to find a tiny screwdriver and somehow get your hands in there to turn it. I replaced it and put the head of the screws to where their facing the inside of the car, easily accessible now.
