Horn Button Relocation - FirebirdV6.com/CamaroV6.com Message Board
  • Horn Button Relocation
    Inspired by the other thread about horn buttons..
    I actually hate that my horn is on the steering wheel. When I actually feel the need to use it because of some jack hole, it's kinda hard to hit cause I'm moving the damn wheel to avoid said jack hole. I don't imagine this would be hard to do, just wondering if anyone else had thought of it before. And, the real info I need is.. What are the wire colors and maybe an easily accessible plug I can get to other than splicing into wires?
    TEAM C6V6
    Re: Horn Button Relocation
    I've had mine relocated after the contacts inside the airbag unit wore out and it was permanently stuck on (also cost me a horn). Shop did it (i had forgotten the horn had blown) so I'm not sure of wire color but i now have a dash mounted button. I'll see if the wire color is apparent.
    96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
      I believe the European version of the camaro has the horn on a stalk on the steering column as all other European cars have had for 40 years. It makes
      much more sense. You would need to contact a GM dealer in Europe..
      Hugo van der Goeslaan 1a
      5643 TW Eindhoven, Noord Brabant, Netherlands
        I don't really need that much research for this project, but that's interesting that Euro cars already have them elsewhere.
        TEAM C6V6
          4 days ago
