R.a.p. - FirebirdV6.com/CamaroV6.com Message Board
R.a.p.
  • R.a.p.
    Going to try and keep this short and sweet. What started out as replacing my window motor has turned into a bigger project because I didnt pay attention. I ended up crushing the original terminal for the window switch and ended up purchasing one through GM. Well I started to cut wires, (had the battery disconnected) and figured I was good to go. So when I connected the battery I went back to the window switch and noticed smoke pouring out (go figure, I looked at my picture upside down I had taken with my phone.) Afterwards the radio stopped working as well as both power windows. I checked all fuses and even checked the 30 amp fuse by placing it into the power seat slot to ensure it was good. Well everything I read is indicating its a R.A.P. issue. My questions is this. Looking at a diagram I found online if I jump the blue wire to the brown wire, by-passing the R.A.P. this should hypothetically solve my problems I am having. I am certain my car does not have the B.C.M. in it, from what I have read, but I am taking that with a grain of salt because you cannot believe everything read online now a days. If I am headed in the right directions let me know, if not then what route should I take? This is my daily driver so I cannot really afford to take it to a shop and lose out on my car. Thanks in advance.
    Here is a link of the schematic that I am looking at.
    http://shbox.com/1/rap_schematic.jpg
    Re: R.a.p.
    probably gonna need the year of your car to help. i have an 01 and it does have a bcm.
      Re: R.a.p.
      Sry I thought I had included it. Its a 1995 Chevy 3.4L Base. I found the RAP module and pulled it out and its burnt.
