After finally fixing my IC fuse opening problem with your help:bowdown: I then swapped my bulbs to green leds. But since im using my stock 00 firebird cluster the only thing green is the km/h numbers & the cross stitch at the end of the redline. :( I just found a thread where a guy removed his red film on his T/A to clear with acetone and etc...:D I want this to be my next mod since im on zero budget status right now. So when I remove my needles should the car be at op/temp? Or should I just get a scanner from work and try to gauge the placement with the computer?
Cluster needle install??s
