NONE of my gauges work after LS1 swap.. - FirebirdV6.com/CamaroV6.com Message Board
  • NONE of my gauges work after LS1 swap..
    Only one that works is volts gauge. Tachometer has 12 volts. Fuel wire is connected ... what else?
    I don't have the answer to what could be the problem. But I do have an LS1 gauge cluster should you decide to switch to that.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
      Re: NONE of my gauges work after LS1 swap..
      I think its a wiring problem because alot of others are able to use the V6 Gauge cluster just fine. Even those with problems just say the Tach is off, but mine isn't even working. Not to mention it's not the only thing thats wrong, my fuel pump didn't prime turn-key but I found a way around that
        Probably a wiring issue in one of the plugs in my picture. I remember that the wiring for the gauges went through there when we did the lt1 swap, but it might be different for you. You may just have to repin a couple of them.
