Only one that works is volts gauge. Tachometer has 12 volts. Fuel wire is connected ... what else?
NONE of my gauges work after LS1 swap..
Re: NONE of my gauges work after LS1 swap..
I think its a wiring problem because alot of others are able to use the V6 Gauge cluster just fine. Even those with problems just say the Tach is off, but mine isn't even working. Not to mention it's not the only thing thats wrong, my fuel pump didn't prime turn-key but I found a way around that1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
