high beam switch - FirebirdV6.com/CamaroV6.com Message Board
high beam switch
  • high beam switch
    so i have a question i have a 98 camaro and when i click on my high beams the lever almost gets stuck to the point i cant click it back to my low beams. I was wondering if anyone had an idea what it is? maybe the turn signal lever or switch?
    Re: high beam switch
    IIRC there's a shaped piece of metal that sits on the end of the lever, and pushes a button at that other end, inside the column, to turn em on. Left side of your steering wheel, there's a plastic cover that just pops off to expose all that. Should be able to get a look at it from there...
