Starter issue - FirebirdV6.com/CamaroV6.com Message Board
Starter issue
  • Starter issue
    I bought a Remy starter for my 3.4L and it sounds to me as though they are slight clearance issues between starter gear and flywheel teeth...
    Have anyone ever experience this??
    Re: Starter issue
    idk about remy but i've had to shim most re-manufactured starters.
      Re: Starter issue
      Ok how did you go about shimming the starter?? and thanks for the reply.......
        Re: Starter issue
        parts stores will have shims. sometimes they come with the starters. if not. they'll be in the "help" section. they are thin metal shims that go in between the starter and the block. the starter bolts go through them. you'll have to pull the starter and add shims until it sounds normal.
          Re: Starter issue
          Ok thanks very much
            Re: Starter issue
            Both of my cars that required new starters had shims even on the OEM starter. Shimming is probably pretty common. And, wow, I could tell when I forgot to add the shim the first time.
