I'm using the pin out data provided on this site to wire up a 97 3.8 into my Jensen Healey. I cannot find a reference regarding a circuit for the tachometer. Where would it be. Any help? Thanks Rich
When I wired an aftermarket tach to my v6 harness I had to use an auto meter tach signal adapter, and I used the pink wire on the connector that plugs into the ICM for a signal.
