does anyone know the bulb numbers for the rears to convert to LEDs? I was using superbrightleds.com and some of their stuff doesn't seem to match up but I was wondering if anyone knew if they still worked or not.
Plus if I was going to do the blinkers and brakes, do I need the load resistors and/or flasher kits they mention on the website? Is that just a matter of splicing in a resistor in series to the socket?
