LED rears - FirebirdV6.com/CamaroV6.com Message Board
LED rears
  • LED rears
    does anyone know the bulb numbers for the rears to convert to LEDs? I was using superbrightleds.com and some of their stuff doesn't seem to match up but I was wondering if anyone knew if they still worked or not.
    Plus if I was going to do the blinkers and brakes, do I need the load resistors and/or flasher kits they mention on the website? Is that just a matter of splicing in a resistor in series to the socket?
    Re: LED rears
    Here is what I used. Of course you can get different Intensity
    Tail lights/ brake lights X2 in RED
    https://www.superbrightleds.com/more...led-tower/633/
    Turn signal X2 in AMBER
    Reverse light X2 in COOL WHITE
    in the 2001 Camaro they also had (1) 194 bulb on the outer edge of the tail lights. I think this is what I ordered in RED
    https://www.superbrightleds.com/more...edge-base/206/
    If you are just doing the rear OR front in LEDs you will be fine with just swapping the bulbs and keeping the same flasher. Now if you're doing BOTH front and read you will need 2 new flashers. 1 flasher for the turn signals and 1 for the 4 ways. If you get the flasher I have you won't here the "clicks" when the turn signal is on.
    LED Flashers X2
    https://www.superbrightleds.com/more...asher/781/835/
      Re: LED rears
      I don't know ... the LED lights remind me of christmas tree lights...its weird
      Phil
