Ok so I have been having issues with converting my cluster. So I have a 2002 chevy Camaro with a 3.8L, I just bought a 98 cluster from a Z28 Camaro 5.7L. The issue I am having is that when I plug the 98 cluster in it does not light up when the lights are on. The gauges seem to not work at all. The Brake In Ops light is on and I think the air bag was the other light is on. So My question is, is it not a plug and play? Do I have to rewire the cluster? Or is this cluster just not compatible with my car. Do I need to buy a 98-02 Z28 cluster? Also the reason why I am wanting a Z28 cluster is the normal reason why everyone else does. I want it to have a 150 mph and not the 120 cluster. I have done a lot of searching but I cant fine anything specific with my year and what year cluster I would need. Any help would be appreciated and thank you so much in advance.
Need help with a cluster
