Turn Signal Problem!!!! Wont work at all!! - FirebirdV6.com/CamaroV6.com Message Board
  • Turn Signal Problem!!!! Wont work at all!!
    I have a 93 Firebird and all of a sudden today when i was driving my turn signals stopped working. When i click the lever to either side nothing happens. No lights, no clicking sound no nothing. Fuses are good. I have not idea what could be wrong. Can someone help???
    Your flasher probably died. It is located behind the knee bolster right next to the A/C controls. It's a $2 part at your local parts store.
    Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
      Great! Thanks alot i will check it out.
        Re: Turn Signal Problem!!!! Wont work at all!!
        any more details on this>? this happened to me today
        i have a 2000 camaro
          Similar happened to me, the turn signal arrow would go on, but no flashing, clicking, or working turn signal. Ended up that my front bulb just burnt out. The flasher units in our cars are based off of a metal strip that bends when it heats up, breaking the connection, cooling, and then contacting again, and repeating. When my bulb was burn out, the arrow was still going on, but the issue was that the piece of metal did not have enough current flowing through it to break contact and repeat. Replace the out bulb, and you have more current, hence more heat, and the flasher works properly again. I suggest you just replace your bulbs. mine didn't look burnt out at all, fillament was intact, but upon replacement, everything worked flawlessly.
            He said they wouldn't light up either though. Even with a bad flasher, they will still light up, just wont flash.
              ummm...... that was 7 years ago... just sayin
