1993-2002 Camaro / Firebird Interior Electrical Information - FirebirdV6.com/CamaroV6.com Message Board
This is a sticky topic.
  • 1993-2002 Camaro / Firebird Interior Electrical Information
    Condensing our stickies in this section. The below hot links will help you answer any of the following questions that you might have regarding 1993-2002 V6 Camaro / Firebirds:
    • Can I upgrade my Camaro / Firebird lights to LED?
    • How do I convert my Camaro / Firebird lights to LED?
    • How do I convert an LS1 dash into my V6 Camaro / Firebird?
    • How do I get the low coolant sensor from the LS1 dash to work on my V6 Camaro / Firebird?
    • What device can I use to help me diagnose electrical problems in my Camaro / Firebird?
    • How should I wire up my subwoofers to my amp in my Camaro / Firebird?
    • Can I add a CD changer to my factory radio in my Camaro / Firebird?
    • Where can I find a remote turn on for my amplifier in my Camaro / Firebird?
    • Can I replace my stereo and keep the Bose or Monsoon system in my Camaro / Firebird?
    • Where is the Monsoon amp located in my Camaro / Firebird?
    • How do I remove the factory radio in my Camaro / Firebird?
    • Where can I get my Camaro / Firebird headunit wiring information?
    • Who has a wiring diagram for an alarm install in my Camaro / Firebird?
    • How do I replace burnt out LED lights in my Camaro / Firebird steering wheel controls?
    • What do these error codes on my stereo mean for my Camaro / Firebird?
    Hot Links
    Still trying to find oil leak
    2 days ago
    Getting some work done on my truck
