So after my double din install I noticed my battery draw is gone. My single din Kenwood I think was bad and ever since I installed it I had a battery drain. Until now I’m thinking it was the problem. Installed the single din Kenwood about 8 years ago and thinking back that’s when I started to get the draw. I let it sit for 2 days without the tender and it started up fine. Now I going to try for 3 days and hopefully I can get it up to a week or more. Before the battery would be dead after 2 days. When I did the double din Kenwood I wired it up the same, so it’s not the wiring. Also with the single din Kenwood, I noticed a loud beeping sound when I turned off the stereo with the car running and the double din doesn’t. So I really think the single din was the problem all along. What do you guys think?
Anyone ever had their head unit drain the battery
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
3 days and still starting fine, going to try and see if 5 days is good and if does I know it was the head unit.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Let the Camaro sit 5 days and still no draw on it ,started right up, so definitely the other stereo. Never heard about a stereo draining the battery but I guess there’s a first for everything. Side note been chasing this draw for 10 years , remembering back 10’years ago I installed the single din Kenwood and that’s when the draw was happening, I remember pulling the stereo and it was wired fine. Wired my double din exactly the same, just 3 wires black, yellow, red so not too much difficultly wiring.Last edited by ssms5411; 12-01-2020, 08:46 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
The last time I had a draw it was from the solenoid of the starter. I went through 4 batteries and autozone doesn't want to honor the warranty anymore.
I found out when I smelled something burning when I installed a new battery and from below I saw the solenoid started smoking. I quickly unplugged the battery.
Wow, that’s scary Edgar, thinking back I had the head unit for 10 years and that’s when I had battery issues, I went through a couple of yellow top Optimas , I used the battery tender for about a year. I’m going to see if I can put one of my fuses back in , I think it’s a 10 amp , before it would blow when I put it in so I’ll see if it still does. Last time I had the fuse in it blew right away so I’ll try it again.Last edited by ssms5411; 12-05-2020, 10:46 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
