OK, so drove home fine no issues. Went to start next day and normal ding ding from key in the ignition then try to start and just get a couple clicks then nothing. even the dome light goes out. I figure there must be a breaker somewhere that is tripping because after waiting 15 to 20 minutes I can do the same thing all over again. I've checked the battery and its holding 12.6 volts. Even with a jump it still does the same. If anyone has any ideas for what to check next, it will be greatly appreciated. Thanks
96 won't Start.Battery good, ding from key trying to start,couple clicks then nothing
Is it throwing in security lights? Could be the key,vats problem try a spare. Does the fuel pump prime up when you turn the key? How old is the starter? Just throwing stuff out there.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostIs it throwing in security lights? Could be the key,vats problem try a spare. Does the fuel pump prime up when you turn the key? How old is the starter? Just throwing stuff out there.Last edited by gatormike69; 03-30-2022, 06:43 PM.
Try checking your starter and starter wire to the battery.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
If all the wires and grounds are good, could be a BCM issue. https://highperformancejunkies.com/h...dy-bcm-repair/
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 days ago
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 weeks ago
