Going to start tomorrow on finding my draw on the Camaro, if I let it sit for a day or two it won’t start. Any tips on finding it. I was just going to pull fuses and check with voltmeter.
Draw on the Camaro
Draw on the Camaro
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
I have the same issue - put a charger on or start Wed - otherwise won't make it from Sat to Sat for my weekly drive.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGT View PostI have the same issue - put a charger on or start Wed - otherwise won't make it from Sat to Sat for my weekly drive.
Didn’t find much, noticed the accessories fuse had volts on each side, 7 volts on one side and 13.7 on the other side, makes me think it’s drawing too much. I think I’ll have the mobile mechanic take a look. I’ll try and pull the fuse and see if it still drains within 2 days.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
So found my radio is wired to the accessory fuse , I remember I had problems with the radio wires shorting about 10 years ago and rewiring to get it to work and that’s about when I had draining problems so I’ll look into that. That’s when I was doped up with OxyContin so memory isn’t too good. Did alot of things I don’t remember.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Going to wire in a relay for the remote turn on for my amps and the 4 3” fans I’m wiring in( making a cover for the amp rack and having the fans blow through. Should take a good load off the remote turn on since I’m wiring the relay off the battery.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Haven’t tested if the relay helps, started doing the amp cover with the fans. Got all the wood cut and the fans and vent parts. Also got the carpet so should finish by next weekend.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got the wood cut, carpet , fans mounted and vents on just waiting on parts so I can finish. Here’s what it looks like so far.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 2.8 Bird View PostWhat's it for Steve.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 2.8 Bird View PostOh OK. Very nice.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got the relay wire in and fans are working, waiting on the brackets to mount everything hopefully Thursday. Do some other stuff but once I’m done I’ll rewire the radio, see if that is the draw.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got the brackets today hopefully finish tomorrow and I’ll post pics.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
So I’m trying a remote battery disconnect on the negative terminal on my battery. Suppose to cut the battery off at 11.9 volts. So it will still start, so far I let it sit overnight and fired it up with no problems. I’m going to try 2 days and see what it does.Last edited by ssms5411; 03-04-2024, 12:41 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
