Over 24 hours and still starting up , going to try 2 days.
Draw on the Camaro
Let it sit for 2 days, wouldn’t start, hit the on button on the remote and it started right up. My stereo even had the time and my settings. I’d recommend it , if you have battery problems. Here’s the one I got.
https://a.co/d/3LKA2lE08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Picture of install please.
Raven
Originally posted by FirebirdGT View PostPicture of install please.Last edited by ssms5411; 03-09-2024, 09:25 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Forgot - you moved your battery to the trunk. I still have the factory type side post.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGT View PostForgot - you moved your battery to the trunk. I still have the factory type side post.
something like this then just get another negative terminal to attach the original negative cable to the new battery post. I like the posts with the stud on
https://www.walmart.com/ip/EverStart...able/497929686Last edited by ssms5411; 03-09-2024, 09:13 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I actually have a set - on my spare battery for charging.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Amazon has 3 units that all look the same but different brands??Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGT View PostAmazon has 3 units that all look the same but different brands??
I posted the link to the one I got, it’s the Matel one.
Did you see the other brands of the same unit? If so, why did you get the matell?Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGT View PostDid you see the other brands of the same unit? If so, why did you get the matell?
Didn’t check out the others, I had bought one on EBay and it didn’t work, also it didn’t have the cutoff at 11.9 volts. I’m happy with the Matell .08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Well not totally sure but I think the ignition wire going to the starter was failing and that was my draw on the batteries. Went 10 minutes with the key on sitting and still started. I’ll try longer later on today. Only been trying to find the draw for 13 years.lol08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
