Questions about Eclipse HU - FirebirdV6.com/CamaroV6.com Message Board
  • Questions about Eclipse HU
    Hi All,
    My mother just got a pimped-out '02 Denali, and I'm trying to set the clock on the HU.
    It's a few years old, model CD-3421. Tapping "function" once and then trying to adjust it does nothing [apparently this is how it's done on the new ones].
    System is interesting overall, though-- 4 Boston Acoustics coaxials, one Boston 12" in a custom box built into the rear corner, a bridged Clarion 2-ch for the sub, and a 4-ch clarion for the doors, with a half-farad cap and some professional looking wiring. Sub box leaks a tiny bit of air, but overall it sounds pretty good, albeit a little "in your face".
    Oh yeah, one more question- the "fuse" off the + battery wire looks more like a circuit breaker with a reset button. Unusual? Couldn't figure out how to disable it, like if I was going to attach a battery cable. Thanks folks!
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
    No, it's not unusual. You can either use a "fuse with a fuse holder" or a "circuit breaker" like you have. Though I've never actually used a circuit breaker, I've read a few times that they lose their accuracy once they've been tripped a few times. Personally, I would replace it with a good old fashion fuse. This way you can just pull the fuse if you need to work on your system.
    [ December 28, 2004, 07:55 PM: Message edited by: nda0602v6 ]
    2006 Tiburon
