NEED HELP BAD with HU install!!!!!!!!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • NEED HELP BAD with HU install!!!!!!!!!!!
    i have a 94 camaro with the bose/delco system, i'm trying to put a new system and i used the schosche wiring harness and interface but the head unit won't work, the hu had power goign to it, it lights up and plays a cd and everythign but there is no sound coming out of the speakers, anyone who has put a hu in there camaro please help me, please, give me a detailed instructions how to do it, PLEASE!!!!!!!!!!!!!!
    1996 Chevy Camaro SS<br />#67 of 2,410 made that year with the slp package<br />Street Lethal Fbody Association Member<br /> <a href=\"http://www.cars-on-line.com/97cam11475.html\" target=\"_blank\">http://www.cars-on-line.com/97cam11475.html</a>
    PLEASE ANYONE??????????????
      Check your remote wire and make sure its hooked up I had the same problem in a different vehicle.
        all the wired are hooked up i double checked them all, i just can't figure out what else to do, I NEED HELP PLEASE!!!!!!!!
          From what I understand, doesn't each of the Bose speakers have it's own small amp? Well, if that's the case you'll want to buy some new speakers.
            You will need to replace the speakers or buy a Bose adapter.
            -Mike
            <b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
              i have the schoche wiring harness and i have the schoche interface which they say is supposed to be what i need to hook up my system but it hasn't worked? what did you guys do???
                PLEASE GIVE ME HELP???
                  Alright well on mine i had a diffrent adapter but dose yours have several slots on it where you could put a small screwdriver in and adjust some dials? if so then you will need to dial them in until you hear sound from your speakers which i did but then i found it added alotta noise to the system and it didn't sound as good anymore and i called a rep and they told me to By pass the kit take it completely out and hook only the Positive side of the wire up and then ground all the rest which i did that and well it worked but sounded even worse so i finnally said to hell with it and put in new speakers and ran new wire to the speakers so if i decided to trade the car i could put it back to stock
                  Well i hope that helps you out some good luck
                  [img]graemlins/thumbsup.gif[/img]
                  <a href=\"http://www.sounddomain.com/id/boboboom2\" target=\"_blank\">White 96 RS t-tops Auto 3.08 gears</a><br />Check link for car and all mods<br />USACi Outlaw Spl and SQ competitor<br />Soon to come Batmans SC running 10 psi and PCM programing<br />99 Honda VFR Motorcyle 100.5hp@10,750RPM 1/4 11.14@122mph, 0-60 3.36sec, 0-100 7.92sec<br /><a href=\"http://www.sounddomain.com/id/boboboom\" target=\"_blank\">99 Dodge 2500 Cummins Quad cab 5 speed 325hp</a><br />Check link for all mods and pics
                    thanks for the advice, i just didn't want to have to strip everything out and put new stuff in. any one else put a new hu without having to put everything else in???
