who has manual fan switch... show me your switch..(updated w/pics) - FirebirdV6.com/CamaroV6.com Message Board
  • who has manual fan switch... show me your switch..(updated w/pics)
    what kind of switch do you guys use?
    i bought the one from radio shack... its a DPDT switch.. mini switch though.. i would like a bigger one.. preferably a rocker switch..
    what kind do you have?
    [ January 08, 2004: Message edited by: Tyler ]
    [ January 11, 2004: Message edited by: Tyler ]</p>
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    All my info is here [img]smile.gif[/img]
    Fan Mod
    1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
      ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
        switch on the right, lights work too for hi and low speed [img]smile.gif[/img]
        Ryan.
        [ January 06, 2004: Message edited by: slow ]
        [ January 06, 2004: Message edited by: slow ]</p>
        1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
          i dont want to use LED's.. so how would i wired the 12v power to it?
          ... like this?
          will it work like that? or will i need 2 seperate power supplies?
          or will i only have to tap the LOW speed wire to the power? since when high is on.. its all connected at the switch?
          [ January 07, 2004: Message edited by: Tyler ]</p>
            12V source is to power lights/LEDs only.
            You are only grounding the wires from the engine bay, so you should be able to hook it up like normal minus 12V power source.
            You might not understand this, but what you are actually doing is grounding relays that control the power to the fans. There's a 12V source already connected to the relays and by providing them with a ground you complete the circuit.
            http://electronics.howstuffworks.com/relay1.htm
              ehh.. maybe i did something wrong..
              ill figure it out tomorrow.
              maybe i'll just end up putting in the lights... [img]graemlins/crybaby.gif[/img]
                <blockquote>quote:</font><hr>Originally posted by Tyler:
                then whats the point of having the switch if there is no power to be added to the line in order for the fans to run...???
                isnt the whole switch idea to Connect a power supply to the line to operate the fans?
                thus im pretty sure i DO need a power source..
                i know this.. because i already tried it without the power source.. it did nothing..
                <hr></blockquote>
                Nope, the whole idea is to ground the relays that control the power to the fans. The switch is there to complete the circuit.
                Try this: take the low fan speed wire (can't remember the color) and connect it to the cigarette lighter ground (-). The fan will turn on, see? If you connected both wires to the ground the fans would turn on high.
                FTI: A relay is like gate. You put power across the gate to allow it to open. In our cars, the PCM will put power across the relay to open the gate and the power now going through the gate goes from the battery/alt to the fans (not from the PCM to the fans) Thats a simplistic version, but I hope you get the point.
                <blockquote>quote:</font><hr>ill figure it out tomorrow. <hr></blockquote>
                Feel free to email or IM if you need anymore help.
                [ January 07, 2004: Message edited by: Dojo2000 ]</p>
                  ground pin J for low speed, and pins J and H for high.
                  the lights in my switch, are just so i know when they are on, and i have 2 relays, so the switch operates +12 volts, but the car sees ground when the fans are on.
                  Ryan.
                    [img]graemlins/thumbsup.gif[/img] it works!!
                    im telling you.. my soldering is getting damn good!
                    anyways.. thank you guys for all your help. i overestimated the difficulty of this mod.
                    i'll take pictures of where i located the switch.. and how i ran the wireing..
                    i didnt bother running the wires through the firewall. didnt have the patience to take off panels.
                    it may be a day or so before i get pics up. friday is my day off so i'll do it then.
                    once again. thanks guys
                      i used the same one whiteshark used. check his instructions at www.cardomain.com/id/briansr
                      edit, nevermind, i see you allready got it done :D
                      [ January 07, 2004: Message edited by: Loochy88 ]</p>
                      Visit My F-Body Page
                        those will work, but will give a ses light on OBD-2 vehicles.
                        Ryan.
                          yea.. i got an ses light..
                          what will i do to NOT get a code?
                            <hr></blockquote>
                            What? When did it go off? Are you leaving the fans running all the time? A SES light is easily avoidable with a fan switch.
                              well as a test i drove to work with the fans on high the whole time..
                              started the car, flipped the switch to high.. got to work.. turned fans off.. then shut car off..
                              half way there i got the ses light
