Does anyone have these subs in a fbody or any vehicle at that. I just got both of them today and let me tell you these monsters are hella heavy, they are huge.. I just need to buy the box now and i am all set. So does anyone have these or heard these and can give me their opinion would be great. Thanks
Rockford fosgate HX2RFR3112
<blockquote>quote:</font><hr>Originally posted by Raul602:
Does anyone have these subs in a fbody or any vehicle at that. I just got both of them today and let me tell you these monsters are hella heavy, they are huge.. I just need to buy the box now and i am all set. So does anyone have these or heard these and can give me their opinion would be great. Thanks<hr></blockquote>
i was thinkin of gettin a pair of those bad boyz, what size and ohm rating do u have?\"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
Those things hit really hard I have a buddy that has the HX2 10's in his civic...their not to good for sq though :( all in all you should be very pleased with them though.\'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
those things are also very power hungry...what kind of amps are you plannin on runnin?\'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
<blockquote>quote:</font><hr> was thinkin of gettin a pair of those bad boyz, what size and ohm rating do u have? <hr></blockquote> I have the 12" dual 2 ohm
<blockquote>quote:</font><hr>those things are also very power hungry...what kind of amps are you plannin on runnin? <hr></blockquote> I am going to be running two Rockford Fosgate 1501.bd I have one right now And i will order the other one sometime next week. I hope my systems really hits hard, thats what i am looking for is spl and I hope i am satisfied.
Are you gonna run the amp at 1ohm??? Fosgate doesn't recommend that but im sure they should be fine as long as it doesnt go into protect mode...3000 watts to two power hx2's :eek: thatll pound...\'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
<blockquote>quote:</font><hr> Are you gonna run the amp at 1ohm??? Fosgate doesn't recommend that but im sure they should be fine as long as it doesnt go into protect mode...3000 watts to two power hx2's thatll pound... <hr></blockquote> So if i run one amp to each thats 1ohm right? So how should I do it.
Well fosgate doesn't reccomend runnin thier bd series amps at 1 ohm but I have read that they run in one ohm...If I were you stick with the one 1501bd and upgrade if needed (750 watts to each will hit hard) with one amp you need to wire each sub into a 4 onh load (series) then from there wire them parallel into the mono amp yielding a two ohm load...run that for a while and see how you like it...if needed then upgrade...heres a wiring diagram for you
http://paudio.tripod.com/subwooferwiring.html
yours is Combination of Series & Parallel
If using Dual 2 ohm coils the total load would be 2.0 ohm.
Hope that helps
Matt\'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...8 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
