This amp at 1 ohm? - FirebirdV6.com/CamaroV6.com Message Board
This amp at 1 ohm?
  • This amp at 1 ohm?
    ALright guys, I blew my Lanzar amp (mistake buying one in the first place) so I'm looking at the JBL 1200.1, my queston is, will I be able to run it at 1 ohm? Or should I spend the extra 200 for a Kicker?
    I'd say definiatly go with the JBL they are very nice amps for the money and yes it is 1 ohm stable ;)
    \'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
      The entire BP line is 1 ohm stable. They will not output any more power at 1 ohm vs. 2 ohms. Make sure you look at the actual Re of the voice coils vice what it is advertised as.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        What sub(s) are you plannin to push with this amp?
          you do know that if your subs dont run at one ohm then it dosent matter if your amp does right? most subs are 4-8 ohms and ive only seen a few that were 2, so im assuming 1 ohm subs are probably going to be pretty expencive!
          I\'m so used to doing so much with so little, I can do anything with everything!
            Well there is plenty of ways to get a one ohm load you dont have to have one ohm speakers... e.g. if you have two 2ohm speakers you can wire them parallel and yield a one ohm load...if you have two d4 ohm speakers you could wire the voice coils in parallel and from there wire those two parallel with the amp...and so on ahd so forth...here this link will show you
            http://www.jlaudio.com/tutorials/wiring/index.html
