Which amp for this sub... - FirebirdV6.com/CamaroV6.com Message Board
  • Which amp for this sub...
    Alright, I'm buying this sub right here:
    http://www.adireaudio.com/mobile_aud...rs/tempest.htm
    It's a 15'. Anyone in here run a 15 in the trunk? A guy from Cookville, Tn is going to help build a box. ( http://www.cardomain.com/member_page...iac%20Firebird ). I need to know what size of an amp to get to power this. I kinda need an cheap one! Thanks
    <a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
    It's really gonna depend on the box design. If it's going in a large ported box, it will not handle a ton of power...... a small sealed box and it will probably handle double rated power. A cheap but still quality amp is going to be the JBL BP600.1 $175
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1950218699
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      I'm going for SPL so it will more than likley be a ported box
        Then the 600.1 will be perfect for a large ported box. Any idea on box size? Tuning freq.?
        Red 96' A4 Firebird
        Check it out here!
          Well i want to use ALL of the trunk. Its a convertable so i don't know how many cubic feet i have, but the guy who's helping me build it is going to measure it and see. As i said, I want to make a box that uses the entire trunk with a groove in the top to place the amp in it. As for the freq. I have no idea really. i've read a bunch of people talk about the "magic of 25" so mabey around 25hz?
            If you are going for all out SPL.... then you'll want to tune high. Say around 50-55Hz. But this will sound like cr@p with normal music and you may damage the sub without a subsonic filter. If this is still a daily driver that you want to get loud.... then tune to around 35Hz. If you are going for all out SQ, then around 25-28Hz.
            The sub has a hard time playing frequencies below tuned freq. Infact, if you play them hard below tuned freq. you will cause the driver to unload..... and then..... exploded! That's where a subsonic filter comes in handy. To filter out the low low frequencies.
            I'm sorry I recommended the 600.1. It will not fit your needs well. I mis-read Adire's specs. If you are STUCK on going with only 1 tempest them try the JBL BP1200.1 THAT one WILL give you about 650WRMS at full tilt!! And this time I'm sure!! :D But I really recommend chosing a different configuration for subwoofers. Try two Shivas! Then you will be able to run at 2 ohm. Then you could get the 600.1 and give em' 300WRMS a piece!!!!! Which should be plenty in a large ported box such as yours.
            Red 96' A4 Firebird
            Check it out here!
              i'm going with the brahma, and 1200W of power going to it.
              \'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
                How are you going to have enough airspace? I have about 2.5 cubes ported and it seems to take about half the trunk(where that ledge thingy is to almost the top of the hatch). You could use the rest, but then box design gets extremely complicated. At least the way my friends and I figured it. If you're going for all out SPL, I would say the back seat. But then again, for competing I believe it would put you into extreme class I think? You would be running against the big boys. 15" seems kinda big for our cars. I hit a 140.1 with one ported Lanzar DC-12D 12" I need to lengthen the port a few more inches and I think I could get a few more DB out of it. I could go alot louder, but buy-bye daily ground pounder and hello one note wonder :( . I have thought about going with a L7. I saw a Camaro hit a 148.7 with just one :eek:
                As for you amp, maybe a Hifonics Hecules. I think don't quote me, it has something like 1000RMS and 1500Max. Not 100% sure.
                Good luck and post pics when your done. I would love to see how you worked it out.
                  <blockquote>quote:</font><hr>Originally posted by camaro_speedemon:
                  I need to lengthen the port a few more inches and I think I could get a few more DB out of it. <hr></blockquote>
                  That will lower your tuning frequency and smooth your response. Better SQ.... lower SPL numbers....
                  He's got enough room.....just wait till I finish my new set-up!!! :D Although I still think he should consider a different sub..... Dual 8 ohm coils are giving him a hard time.
                  Red 96' A4 Firebird
                  Check it out here!
                    I've had my eye on the Tempest for a while now. I almost bought one this summer. I just suddenly got the urge for more bass. I don't use my trunk anyway so i figure when not use it all on one big sub.
                      Outstanding choice on the Tempest. It IS a great sub..... but if you are only running one..... 4ohms you'll be runnin' :(
                      Red 96' A4 Firebird
                      Check it out here!
                        <blockquote>quote:</font><hr>Originally posted by 96firebird311:
                        <hr></blockquote>
                        I think I'm tuned a little to high. I think it was something around 60hz, I want to be somewhere around 55hz.
                          <hr></blockquote>
                          Tune to around 50Hz. That way you'll peak at about 53-54Hz. I have found about 53Hz reads highest in the 4th gen F-bodys.......
                          Red 96' A4 Firebird
                          Check it out here!
