My subs are barely playing at all. All I did was put my subs in a new box....thats it. My subs were playing fine before the new box. When I unplug one of RCA cables out of the amp, the one sub thats still plug in begans playing at the normal volume. [img]graemlins/omg.gif[/img] As soon as I plug it back up you can barely here it. It doesn't matter which rca I unplug it plays at normal volume but as soon as I plug both of them up, you can barely here them. Please help I hate my whispering subs.Later
Subs not playing right
sounds like you wired your amp wrong...I can't tell you exactly where because I'm half asleep rigtht now, but you might want to go over all your wiring...something came loose somewhere1999 C5<br />2000 Ford Lightning<br /><i>Don\'t hate me because I\'m awesome</i>
Make sure you have your fuses in and good.
I took my subs out and the amp fuse. put subs back later. they worked but very quiet. forgot to put amp fuse back in. Big booms again2002 Black FireBird M5 2-5-02<br />Red BMR strut bar<br />Dynomax Super Turbo muffler with FastToys.com tips.<br />4 Coats of Zaino - Better every time<p>Need to post pictures? Do it <a href=\"http://www.thenebula.com/carpics/\" target=\"_blank\">here</a>. its <b>easy</b> and <b>free</b>.<br />Change your own oil. <a href=\"http://www.thenebula.com/firebird/oil/\" target=\"_blank\">click here</a>.
Is the box sharing airspace between the 2 subs? If so the box may be too small. If you didn't change the way it was wired when you changed the box, it could be box size. I would double check and make sure everything is wired right. If everything looks OK, then take the box back, its probably the wrongs size.
BTW what kind of subs do you have, and how big is the box that you just bought?<a href=\"http://pics.projectpredator.com/thumbnails.php?album=16\" target=\"_blank\">2003 Zinc Yellow Mustang GT</a> 1 of 701<br />ET : TBD<br />But our shenanigans are cheeky and fun! Yeah, and his shenanigans are cruel and tragic. Which... makes t
