Will a alpine Type-R fit in a thunderform box? - FirebirdV6.com/CamaroV6.com Message Board
  • Will a alpine Type-R fit in a thunderform box?
    Hey guys, I'm just working on finishing up my subwoofer setup and I took a trip to circuit city yesterday. I've got the unloaded thunderform box on the way, all I need now is the sub. I've got it down to either a 10" alpine type-e or a 10" alpine type-r. Everyone has told me that the type-r will not fit in the thunderform box due to it's huge voice coils. So I think I'll be geting the type-e, it really impressed me. All I'm wondering is that are these guys right when they say the type-r won't fit in the box? Have any of you guys done it before?
    Thanks alot
    1996 Pontiac Firebird: A4, Flowmaster 80 Series, dual 3\" Stainless Steel tips, SLP CAI, Alpine CDA-9813 deck, Infinity speakers, Alpine Type R sub, MTX Thunder 801d amp, Tsunami 2 Farad Capacitor.<br /> <a href=\"http://www.cardomain.com/id/firebirdfury\" target=\"_blank\">http://www.cardomain.com/id/firebirdfury</a>
    <blockquote>quote:</font><hr>Originally posted by FirebirdHatesRice:
    Everyone has told me that the type-r will not fit in the thunderform box due to it's huge voice coils. <hr></blockquote>
    Ok. Whoever, told you that is the moron. The size of the woofers voice coils has nothing to do with it. I'm not 100% sure it will fit in the thunderform, but I know the Type-R will fit in subthump's stealth box. Check out the web and see if you can find the thunderform's mounting depth.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      what I meant was that the depth of the type r was too much for the box. According to the install guys at circuit city, the box isn't deep enough for the speaker. The thunderform is around 12" deep I believe, so I really didn't see the type-r causing trouble, it looked to be 9-10" deep at best.
        Damn, the only sub ive ever seen even close to a foot deep are DVC subs like the W7.
        Alpine Specs:
        Type-R 10" SWR-1021D
        Mounting Depth (top mount) : 152mm (6”)
        Reccomended Box Types : Sealed/Ported/Bandpass
        Recommended Sealed Box Volume : 0.55 – 0.8 cu. ft.
        Type-E 10" SWE-1041
        Mounting Depth (top mount) : 148mm (5.9”)
        Recommended Box Types : Sealed/Bandpass
        Recommended Sealed Box Volume : 0.6 – 1.25 cu. ft.
        Hope that helps.
        [ January 18, 2004: Message edited by: Ian ]</p>
          Heres the dimensions of the thunderform
          Dimensions: 12.125" x 17.125" x 12.125"
          plus the alpine is only an inch deeper than the thuder 6000 that comes in there originally. btw: Ian the 10 and 12 W7's are 3ohm SVC's the only DVC W7 is the 13w7 which is dual 1.5ohm. However you are correct about the w7's not fitting in the thunderform (you would need a custom figerglass enclosure with a spacer ring).
          Matt
          \'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
            so based on the specs, I shouldn't have any problem geting they type-r into the thunderform box? They kept telling me it couldn't fit at circuit city, but based on the depth of the box I dont understand where they were coming from.
              Well I was told many times that my 10w6v2 couldnt fit in the mtx box...but im pretty sure thats true due to the diameter of the manget...I think that Steve (Megabass) could probly give you the most accurate answer.
              Matt
                Just emailed him, thanks again for the help Matt.
                  No problem man. Oh and btw: ikesound.com has got the type r's for 94.50 with a year warranty.
                    so based on the specs, I shouldn't have any problem geting they type-r into the thunderform box? They kept telling me it couldn't fit at circuit city, but based on the depth of the box I dont understand where they were coming from.<hr></blockquote>
                    you'll be fine with the subs in the box. they probably wanted to tell you it wouldnt fit because Circuit City staff is on comission, and they figured they could try to tell you that you needed something 'more expensive' to actually fit.
                      what would be the best amp to run with a set up like that?
                      -Chris<br />2001 Pewter Camaro M5<br />Current Mods: NOS Dry Kit and a few others<br />N/A: 15.5@88.9MPH<br />N2O: ??? <br /> <a href=\"http://www.cardomain.com/id/jtusa69888\" target=\"_blank\">http://www.cardomain.com/id/jtusa69888</a>
                        <blockquote>quote:</font><hr>Originally posted by AZv6camaro:
                        what would be the best amp to run with a set up like that?<hr></blockquote>How much you looking to spend? I assume as little as possible, but still get quality gear? Probably a 2-channel Rockford running in bridged mode. The 401S can be had for like $109 and it'll do 400WRMSx1@4ohms.
                        Red 96' A4 Firebird
                        Check it out here!
