JBL1200.1 + Planet Audio= new alt? - FirebirdV6.com/CamaroV6.com Message Board
  • JBL1200.1 + Planet Audio= new alt?
    Right now the only amp i have is a Planet audio which draws 60 amps at full blast.
    I am soon going to get a JBL 1200.1 which will draw 120 amps at full blast.
    So thats going to equal 180 amps just for the amps. I still have other things like neons,power converter etc...
    I am concerned that i might need a high output alt in the near future. How much power can the stock alt handle?
    Will it be safe to run both of those amps for like 6 months or so while i get a high output alt?
    If i do need one i think i will want to stay away from buying it online. id rather buy it at a store, that way if it goes out i can quickly go and get an exhange.
    thanks
    My car has GPS trackin\',traffic alert,its own phone #,PS2,screens. And What da H3ll,When I Turn da key it says \"You\'ve got mail\"..... <br />I swear and promise.. I\'ve had more cars then Charlie Thomas.. bounces in a Monte\' that hopped.. Pimped old skoo Blazer on Chopz, Today Its a Camaro at all da plya spots.
    i wouldnt use the neons, and forget about using the PS2/Screens unntill you get a HO alt...i have BAD dimming with the volume moderately cranked, and i even upgraded the stock amp/battery wiring...and i only have a JBL80.4 and the 1200.1, no other accessories
      The JBL pulls 112amps max. Just a note. ;)
      Yes, you are going to have bad dimming problems without a doubt. I have two amps. One draws 60amps max and the other draws 90amps max. I had horrible dimming problems. Couldn't even drive the car at night if I wanted to. I installed two 1 farad caps for the time being and that cured the dimming problems.
      Well, I ran into some other things I had to pay for.... so the caps ended up staying on for like 2 years. Not one problem the whole time. Now I have a H/O alternator from Irragi Alternator. Couldn't be happier. [img]smile.gif[/img]
      Oh, and the neons are no big deal. They pull very little amperage. Not sure about a power inverter, but it can't be much compared to an amp.
      [ April 27, 2003: Message edited by: 96firebird311 ]</p>
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        neons are like not even .5 amp a peice I Think, and with a cap u'll be fine, but its all in the wiring. Ive ran my Crunch 1000watt amp a full set of neons forever and no dimming. ****, I even ran 800watts AC threw a DC ac converter to run my Xbox and a full Projector and it didnt even dim it. People have a big misconception about the ability to create power, I did all that without a cap. Just get proper wiring.
        97 Special Edition Bird , Short bus stlye special
          <blockquote>quote:</font><hr>Originally posted by Takumi Fujiwara:
          neons are like not even .5 amp a peice I Think, and with a cap u'll be fine, but its all in the wiring. Ive ran my Crunch 1000watt amp a full set of neons forever and no dimming. ****, I even ran 800watts AC threw a DC ac converter to run my Xbox and a full Projector and it didnt even dim it. People have a big misconception about the ability to create power, I did all that without a cap. Just get proper wiring.<hr></blockquote> Like I said, I'm not 100% sure how much current a converter can pull. But if you think about it..... how many things can you plug into a wall socket at your house? Quite a few, huh? Now go to your circuit breaker box and check out the size of that breaker. Not very big huh? And chances are that one breaker powers several wall sockets. So how many things can you plug into several sockets?
          I'm just saying I don't think that converter pull enough to really even worry about. Not when we're talking 100amps per amplifier.... what was the fuse rating of your Crunch amp? And do you know what a cap REALLY does? Seems you are the one with the big misconception....
          Red 96' A4 Firebird
          Check it out here!
            The power converter has (2) 20 amp fuses built into it.
            And i know for sure i am not going to waste $$$ on a cap. All a cap does it puts a band aid on the problem, the problem is still there just not visible.
            Besided a cap just puts more strain on the alt b/c its one more item it has to power up.
              <blockquote>quote:</font><hr>Originally posted by CAMAROWITHBASS:
              <hr></blockquote>
              Yep. That's pretty much correct. Shoot an e-mail to dom (addy in sig) for a new H/O alternator. You won't be disappointed.
              Red 96' A4 Firebird
              Check it out here!
                The JBL pulls over 100 amps? I have the JBL 1200.1, and it only has 3 20 amp fuses (60 amps)- how can it draw over 60 amps without blowing it's fuses?
                I've popped a couple of 60 amp fuses when the amplifier is turned up past half power- can it do more than 60?
                All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
                  if im not mistaken it should have (3) 40 amp fuses.
                    Oh, to whoever talked about the household breaker current:
                    Think about it in terms of power, not amperage.
                    Sure, our household breakers are 20 amps. But get this, that's at 120 volts. Your wattage is the amps times the volts!! so we're talking 2400 watts from that one circuit.
                    Now, the reason your amplifier is such high-amperage is because the car voltage is 12 volts. Multiply your 12 volts by 100 amps and you only get 1200 watts. Still less than household with 5 times the amperage.
                    1997 Camaro 30th Anniversary...M5, chrome 16\" 5-stars Goodyear 245/50R16<p><a href=\"http://members.cardomain.com/issycamaroman\" target=\"_blank\">http://members.cardomain.com/issycamaroman</a>
                      <blockquote>quote:</font><hr>Originally posted by youngcamarokid:
                      <hr></blockquote>
                      Ok...... I realize that..... what is your point? We were talking about a power inverter. Which outputs 120V 60Hz.
                      Red 96' A4 Firebird
                      Check it out here!
                        <blockquote>quote:</font><hr>Originally posted by 96firebird311:
                        <hr></blockquote>
                        That would be the post above I'm referring to, just trying to clear that up.
                          That would be the post above I'm referring to, just trying to clear that up.<hr></blockquote> Ok. I still don't know what your really trying to say.
                          I was just trying to show him how much stuff you can actually plug into a socket. It was an attempt to show that your run of the mill household good doesn't draw much juice. Yes, the breaker size is small and yes, I realize that is at 120V, but that is really irrelevant in this case.
                          It sounds like he is running a PS2 off a power inverter..... which outputs 120V 60Hz.... just like in a house. I said I wasn't 100% sure exactly how much current an inverter can pull.... and two 20amp fuses was a little bigger then I expected but still pretty small compared to the 100amp draw of an amp. I bet it draws maybe 10amps with just the PS2 plugged in. Maybe..... but I doubt it.
                          [ May 05, 2003: Message edited by: 96firebird311 ]</p>
                          Red 96' A4 Firebird
                          Check it out here!
                            The PS2 will say on the bottom how much current it draws. Multiply that current by 10 to get how much current it would draw at 12v (bear with me)
                            Anyway, add 1 or so amps to that value to get the approximate draw of the inverter w// PS2
                              The PS2 will say on the bottom how much current it draws. Multiply that current by 10 to get how much current it would draw at 12v (bear with me)<hr></blockquote>
                              Ok. I follow ya.
                              <hr></blockquote>
                              WHAT??!!?!? Add 1 amp to the current draw of the PS2? Or add 1 amp to the number you would get if you multiply by 10??? What are you getting at?
                              Red 96' A4 Firebird
                              Check it out here!
