factory cd player - FirebirdV6.com/CamaroV6.com Message Board
factory cd player
  • factory cd player
    Would the factory CD player from another F body fit my dash and use my wiring harness?
    Clay Kreiling<br />1997 Camaro 15.767@88.24MPH
    depends if it is from a monsoon system,some years on others are different too
      which ones could I use?
      97 Camaro..
        <blockquote>quote:</font><hr>Originally posted by WannaBeGTZ:
        97 Camaro..
        <hr></blockquote>
        Any year Delco. I put a 2001 Delco CD in my 96, dealer even did it.
        Raven
          I'm not 100%,I believe any GM will work just not the monsoon
            <blockquote>quote:</font><hr> I'm not 100%,I believe any GM will work just not the monsoon <hr></blockquote>
            Are you sure?? There is no difference in how the monsoon deck functions from the standard decks. The external amp is what makes it a monsoon system.
            <b>1998 Cayenne Red Camaro 3.8 A4</b><br />-Whisper Lid, K&N, manual fan switch, DEI 508D<br /><br /><b>FOR SALE:</b><br />-Whisper Lid<br />-PAC OEM-1 adapter<br />-GM Delco 12 disc CD Changer<br />-MTX 4250D amp<br />-Kicker Free Air subs<br />-DEI 508D Proximity Sensor
              I think the monsoon runs a third set of speakers
                The monsoon outputs are line-level and will not drive speakers.
                I don't know about the 1997 dash, but my 95 has a curved edge on the right that keeps me from using a standard GM head (or aftermarket replacement) unless I cut.
                -Brian
                Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
                  I have the monsoon head unit with my Bose system. I used to have the bose tape deck. Almost 99% positive that all GM Delco HU will work in you car. The fit with the Monsoon HU is a little tricky just have to do a little more screwing but does fit pretty much perfect.
                  <a href=\"http://www.saintsworth.com/z06\" target=\"_blank\">\'02 Corvette Z06</a>
                    That is not correct; the head unit for the monsoon system does not have line level outputs. It is exactly the same as the standard system. The only difference is the little monsoon stickers they put on '99 and later.
                    The monsoon system uses an amp for 6 of the speakers (the tweeters in the front doors are driven directly by the HU), but the amp takes speaker-level inputs (directly from the speaker outputs of the HU).
                    As far as I know GM used the same wiring harness since '88 so you should be able to put any delco HU fron within those years in your car.
                    [ May 28, 2002: Message edited by: TokFan ]</p>
                      <blockquote>quote:</font><hr>Originally posted by TokFan:
                      <hr></blockquote>
                      I wasn't sure about the tweets,thanks for the clear up
                        .. that's funny I have a monsoon HU in my camaro with a bose system.. works fine.. :cool: :rolleyes:
                          Does anybody know what the gm part #'s for a factory cd player are?
                            Wolfy, are you looking to buy one?? I dont know what the part# is but Im sure the dealer will rip you a new one for what they want for one. Probably in the $300 range, maybe more. If your looking for one I might have one for sale. Let me know.
