whats up guys?.....can anyone tell me exactly where this access hole is so i can finish my install....thanks
rubber grommet in firewall
here is a picture of the underside of the hood with the PCM/ECM circled. if you unbolt the holder for the PCM, you will find the rubber grommet down behind it. You really won't be able to see it, but if you stick your arm down there you'll feel it.
To access the other side all you need to do is unbolt the plastic sheild underneth your glove compartment. Try sticking a very long screwdriver through the hole to find out exactly where it leads to. You'll see what I mean.
If you need anymore help just shoot me an email at MA5ornelas@aol.com
[img]graemlins/burnout.gif[/img]~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
I don't know what you are running through it, but when I ran the wires for my amp, I took a metal clothes hanger, and unbent it, to a straight rod, then stuck it through, and taped the wire to it. then just slowly pulled the wire through the rubber grommit, never having to undo the PCM.
goodluck ;)94 bird 3.4L Racing Green<br />80 series flowmaster<br />3 1/2\" Chrome tips<br />Deck, amp, sub, and upgraded speakers<br />Delphi XM<br />5 spoke 99 Trans Am Rims<br />Clear Corners<br />Sylvania Silverstar Lights
having to take out and put back in the pcm is a real B!7@# i'd do what wildcat didStreet Lethal Performance<br />2000 Black Firebird Y87<br />3.42\'s, Torsen Limited Slip, 160 powerstat,<br />Manual Fan Switch, Cutout exhaust, Whisper Ram Air CAI,<br />K&N filter, Zex spark plugs, MSD plug wires, MAF screen removed.<p>AIM: FIREBIRDRUMBLE00<br /><a href=\"http://www.streetlethalperformance.com/profiles/gazmentselman/gazmentselman.html\" target=\"_blank\">Street Lethal Performance Profile</a>
