I will be hooking an Infinity 1020W model 10" subwoofer up to the stock HU with an RCA converter...
Sub specs are
Nominal Impedance: 4 ohms
Power Handling: 250WRMS/1000W Peak
Sensivity 2.83V/1m: 90dB
Frequency Response: 22Hz - 800 Hz
Mounting Depth: 5-1/2" (140mm)
Cut-out Diameter: 9-1/4" (235mm)
Power Handling RMS: 250W
Power Handling Peak: 1000W
Sensitivity: 90dB
Frequency Response (± 3dB): 22Hz - 800Hz
Impedance: 4 Ohms
It's going in a seal boxed, not that that would make a difference in amp choice. I'm looking for a pretty cheap amp that'll get the job done. If anything, just tell me what ratings the amp needs to be and I'll go from there.
Thank
Sub specs are
Sensitivity: 90dB
Impedance: 4 Ohms
Thank
