Wiring a lcd screen? - FirebirdV6.com/CamaroV6.com Message Board
  • Wiring a lcd screen?
    Im adding a lcd monitor to my system and it is all installed except for the power and ground wires. I want the monitor to only get power when the car is on, how should I wire this? Should I run it through the fuse block or what? Let me know...
    you can wire it to the acc wire (yellow i think) or run your own wire, powered by a relay... and have the acc wire connected to the relay...
    White 1998 3.8L Camaro
    Home Ram Air / Free Flow Intake
    Drilled / Slotted Rotors with black painted Calipers
