I can only get to 2 of the 4 bolts that are holding in my stocker speakers !? do i need to take off my whole door panel ... if soo how in the hell do i get it off any help ?
door panel speakers ?
Yes, you do need to remove the door panel.... wondering how you even got to two of the screws..?? Pryed off the plastic speaker grill? You can find a walkthrough here:
http://mods.firebirdv6.com/stereo.html
When I pulled my door panel off, I noticed something interesting.
The door speaker grilles on my 99 Camaro actually snap in to the panels but two of the tabs on the grille get melted to the panel. It seems as if the original idea was to have a removable grille similar to the sail panels but then GM decided to make them a more permanent part of the door panel.
Originally posted by robson:
i got manual windows is the cran kgoing to get in my way ?
Any place sells them.... you could probably find them at a local auto parts shop. Should only be a few bucks.
Very easy to use. Just slip the tool between the door panel and the crank. Like this
That will release a small U-shaped clip that's holding it in place. Don't lose it! It's a little tougher to put back on, but still not hard. [img]smile.gif[/img]
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...6 hours ago
