I have 2 12 inch Orion XTR's and I have a 1997 Camaro Convertible. I began fiberglassing my box today and I was curious would I be able to fit the 2 12's in just the lower well of the trunk? Would there be enough airspace? Or do I have to make a box that takes op the whole trunk? Any suggestions would be greatly appreciated!
I just figured this out now.... the Orion recommends 1.5 cu ft. of air space for each sub. If I just had it in the bottom well of the trunk I would have 2.23 if I added 2 more inches to that I would have 2.7. I know its alittle short of what they recommend but do you think they would sound ok. Could I use polyfill to make up the difference? Also what is better having each sub in its own compartment or just leaving it and not dividing the box into 2 compartments?
The subs I have require about that much space, and I know I'm runing them a little short of it, and they sound just fine. And in my opinion, leaving the box and not dividing it into two compartments would be your best bet. Its been my experience that this usually sounds better
