I just bought XM for my car and i'm having trouble mounting the magnetic antenna on the outside of the car. I have t-tops so there is only a small semi-metallic strip on the roof of my car. They say that mounting the antenna on a non-metallic surface results in a bad signal. Does anyone have an antenna that works well installed? If so, where and how did u route the wire into the car? thanks
Xm Radio Antenna
I just keep mine on the "shelf" right behind the back seat. It works just fine. I then easily routed the wire under the back seat, floor mats, etc.
Don't know why they say it must be mounted on a metallic surface. I have the "Roady" system.Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming: \"WOW!!!!, what a ride!\"
it does need to be mounted to a metal ground...if you notice on the sirius antennas thats why they have that big ol' piece of rubber goin out the back of the antenna....I went and got a glass mount antenna to fix my problems
05' CTS-V
00' Camaro - SOLD :(
go get the terk roof mount antenna and put it on top of the roof bar and run it around there and under the bar to hide the wires that is what I did atleast2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
Well, he was asking about XM not Sirius. My antenna has no big 'ol piece of rubber. It is just a magnetic antenna. (A roof mount). It works great keeping it on carpet between the back seat and the T-Top well.
Blue Flame--Can you explain what you did a little clearer? The roof bar is non metallic.Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming: \"WOW!!!!, what a ride!\"
heres the pic http://www.terk.com/popup.asp?iid=TRKSR20S
except w/XM2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
05' CTS-V
Hey Nikon
Forget your Prozac today?
Secondly if you re-read what I said, if you can, you will discover that I was simply noting what I had done with my XM antenna. I have it where I noted and it works just fine. My manual states that they SUGGEST it being attached to metal.
Why would he or I care about what Sirius does since we both have XM?
Calm down pal.Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming: \"WOW!!!!, what a ride!\"
I bought an antenna that it sticks to the roof...
i put it in center thingy behind the t-tops
i had the antenna ur talking about... the inside part worked alright (like on the shelf in the back) BUTTT if you have a rear tinted window and or defroster u lose a lot of reception ... i have pics somewhere in my fropile<b>*§*Julian*§*</b><br />*~*~*~<br />2000 Grand Prix GTP -Daytona 500 Edition (only 2000 made) - Supercharged 3.8L V6<br /><br />1998 3.8L V6 A4 Firebird w/ W68 package, Y87, T-TOPS!<br /><br /><a href=\"http://myweb.usf.edu/~jadidona/index.html\" target=\"_blank\">MY SITE - CHECK IT!</a>
I put mine under the dash in front of me and I can not see anything and i have had no problems with mine.2002 Firebird.<br />no mods but still a great car<br /> <a href=\"http://www.cardomain.com/id/lastbird\" target=\"_blank\">http://www.cardomain.com/id/lastbird</a> <br />\"It\'s (insert time here) and OU still sucks!\" <br />Hook\'em Horns
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...20 hours ago
