how do u or where do u hook up the air/fuel ratio gauge?
air/fuel ratio gauge hook up?
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
i hooked mine up to directly to the driver's side o2 sensor. the purple wire to be exact. i used one of those wire taps to do it. works great. The power i tapped into the IGN port in teh fuse box. They sell fuse taps at radio shack which you can use for this.....and just ground the gauge somewhere under the dash. I spliced into an existing ground.2002 Pewter Metallic Pontiac Firebird<br /><br />Mods: 3\" Borla Catback Exhaust, SLP Cold Air Intake, Removed Air Silencer, K&N Filter....more to come.....hopefully...
so purple wire on the o2 ok cuse last time i hooked it up on the o2 it shorten my hole system cost me $400 so im just makeing sure where to hook it up2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
