stereo locked - FirebirdV6.com/CamaroV6.com Message Board
stereo locked
  • stereo locked
    well i forgot the code and tried too many times and now it says INOP when i press the hr or min buttons , now what do i do ??? [img]graemlins/crybaby.gif[/img]
    {1995 3.8 A4}{Flowmaster Exhaust}{SLP CAI & Fan Switch}{4 Wheel Disc Brakes}(3.42 LSD}<br /><br />{2004 Dodge Dakota SXT 3.7L SOHC V6}{Cold Air Intake}{Dynomax Ultraflo 2.5\" Catback}<br /><br /> <a href=\"http://members.cardomain.com/95blackbird3800\" target=\"_blank\">http://members.cardomain.com/95blackbird3800</a>
    maybe a dealer can unlock it
      Theftloc Bypass
      1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed
      2. Write the numbers down.
      3. Press the AM FM button, write down the next 3 numbers
      4. Call 1-800-537-5140, when asked, enter 202107, press the “button” and enter the 6 digit code from the radio, you will get an unlock code, write it down.
      5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
      To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
      I think this should be moved to the electronics section. [img]tongue.gif[/img]
        bypass does not work when it goes to inop , the dealer said unhook battery over night and i did but it didnt work :rolleyes:
          found a post on a chevy site , turn ignition to on and leave for one hour and then it will let you get the code
          well it worked [img]graemlins/burnout.gif[/img]
            This should go into the technical archive.
              If anyone has a dealer number that will work would you PLEASE post it. I have tried and tried to get the number that is on here to work but it just does not seem to work!!!
                hello?????????????????????????????
