need more power - FirebirdV6.com/CamaroV6.com Message Board
need more power
  • need more power
    Ok, here's the deal. I've got an Electric water pump, MSD-DIS-4, MSD coil packs, upgraded driving lights, and now a new stereo system putting out 240 watts. All of these combined seems to be putting a serious draw on my electrical system. I'm also looking into putting on an underbody lighting kit this summer. I know I need to upgrade my electrical system. Here's what I'm thinking.
    New power and grounding wires to handle higher amounts of current with less resistance
    Dynabat battery to replace my stock 72000 mile battery
    high output alternator to put out more juice
    maybe an underdrive pulley for the alternator, depending on if I can still get enough juice out of it.
    Do these upgrades sound sufficient for what i've got and am planning on doing? Also, I don't wanna go out and buy a grounding kit or brand name power wires for my car. I'd be just fine with making my own, or just buying some pre-made ones in sections suitable to the length I need. Does anybody know if Autozone or auto parts stores usually carry wires already set up to be attached to the car? If not, where would I have to get the supplies to do this myself.
    From what you have listed, you're not pulling THAT much extra power. However, without a doubt more then the stock charging system was intended for. The H/O alt would be first priority over anything else. Make sure you look for one that has higher output at idle speeds! Looks like it's about time for the battery to be replaced anyway. So I'd go ahead and do that now. And for your wiring, check out www.knukonceptz.com . Their stuff may look cheezy or cheap, but it's quality stuff. Upgrading the alt output wire to 4g is a must. And additional ground wire as well. If you need any help with connections or anything like that, just let us know. [img]smile.gif[/img]
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      I posted on your "Lights Dimming" question....read.
      • Manimal
        Coil springs
        by Manimal
      • Manimal
        Newby here
        by Manimal
