hey guys, just a quick question. I am making my enclosure finally and it is goin well. what i did was make my enclosure but i dropped the sub opening 3 inches from the surface because i am going to put plexy glass flush with the enclosure surface over the dropped sub. my question is that since the top of the sub isnt open to the air, would that hurt my sound output
quick custom sub box question
Pretty confused as to what you're trying to do, but I think I've got it.Basically the front of the sub will be firing into a sealed box. (wood and plexi top)Is that correct? Is this custom box you're making a sealed or vented design? If sealed, yes. Obviously your sound output would be hurt....lost in fact. You've just sealed your sub inside a box.....lol [img]graemlins/stickpoke.gif[/img] If vented, yes and no. Having the front of the sub sealed off, while the rear side using the port would turn your box into a bandpass design. Bandpass boxes usually play a very slim range of frequencies very loud. They are also very critical of error. If you screw up on the design, you could easily run the risk of damaging your subwoofer. Either way, I'm sure you were not intending on do that. If I'm visualizing this correctly, I suggest you re-think your design.
im not positive..but i think you may need to port that chamber and go bandpass..if the voluum is correct for the specific sub you're using<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
yea, sounds like a bandpass box...
you could always drill a bunch of holes in the plexi glass to keep it a regular box...White 1998 3.8L Camaro
Home Ram Air / Free Flow Intake
Drilled / Slotted Rotors with black painted Calipers
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...6 hours ago
