ok, so Ive decided that i am not going to close off the top of the sub with plexi glass and will keep it open to air. My first question is could i use the ported opening from the box the sub came with? (The box the sub came with is a different shape but i am guessing about the same volume of air inside) or should i just keep the box sealed? my second question, since I am only making the enclosure for one 12" sub I will have room on either side of the sub box. would it be possible to put a small speaker on either side of the sub? If so, what would u guys suggest?? also, if u guys could direct me to a site or link as to how to wire speakers that would be great. I have the sub all wired up but am gonna need some help on wiring these speakers if i am gonna do it. Thanx for all your help guys
another quick custom sub box question
SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.Tags: None
naw bro.....i am not that dumb......I mean there is gonna be space on the surface of the enclosure on either either side of sub. that is where i would put the small speakers, not on the actual sub box. looking from the top, it would be the 12 in the center and either side of it would be two small speakers.SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
actually..what make and model sub are you using?..sub volume requirements can change a LOT depending on whether or not the box is sealed or ported..if the volume of your box is about the volume of what this sub recommends for a sealed box i would leave it sealed..but if it is a bit larger i would suggest porting it to get the best sound out of it..especially since you are saying that the box you built has about the same amount of volume as a box you bought..which i am going to guess is a type 2 ported box<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
yea its a rockford fosgate 12er, 4ohm, 1.5 coil, 400w. a guy on the board looked it up for me saying that the recommended volume is 1.25 cubic feet (not sure if that is a sealed or ported volume) but the recommended volume he gave is about the same size as the box it came in and that one was ported. play it safe and keep it sealed or port it?SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
not porting ANY given box..porting the one he made..which from what he says..is about the same volume as the one he purchased for it.. 1.25 for a 12" sub sounds like a type 2 ported box..if its the same volume..same port..seems like he should be ok to me<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
