does anyone know what fan wires you tap into on the 3.4 i dont have a clue as to where there at. i have a 95 by the way.
manual fan question
Here give me a few mintues.... i did a write up on fbodyv6.com with all details..New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
Ok you are going ot find the under hood fuse box first.
Uncradle it from the frame with left to right motions. There is a little green wire going to the "cooling fan relay 1"This the the 2nd relay down on the side that has the double stacked lined fuses.You will want to attach a fused wire to the green wire with a wire gewel. I put a "15" fuse in my wire and it worked fine. I ran my ground to the screw on the side of the hood.( i have a pic of this.
Go through the firewall with the 2 wires.
Attach them inside the car to a 2 prong.
One for the power of the green wire, and one for the ground.
This only cost me around $10 also and works great.
I used 14 guage also.
One red for the power, and the black for the ground
And dont foget a switch
And dont forget a fused wireNew:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
on the 10 pin black connector, passenger side of engine bay.
Pin H for high and pin J for low speed operation.
Ryan1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
