Aftermarket Head Unit Problem. HELP PLEASE - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Guys, thank you for your help, I really appreciate. Just to let you know, I tried to rewire everything again tonight (what a pain to see the different colors using a flashlight;), I gave up trying to use the factory wire harness and Im glad I did. So I had a tester with me and could check which wire was doing what... And after a bit of time, I tested everything...and IT WORKS!!!!!! YOUPEEEEEEEEEEE.No more strange things going on when I switch on the headlights, no more engine noise... Works just fine. The only thing is I sometimes have the head unit which switch off, it seems that there is a bad wire somewhere, it was already doing that with the Monsoon system, and usually the power comes back if I hit the dashboard...
    Anyway, i will sleep better tonight knowing that my system works well, and that I didn't screw big time (and I saved quite a bit of money too).
