Ok, need help...loc to amp - FirebirdV6.com/CamaroV6.com Message Board
  • Ok, need help...loc to amp
    I have a JL Audio 12W6, and an XPLOD amp, as well as a Jensen LOC.
    I don't have monsoon, so I spliced both the rear speakers into the LOC, and connected it to the amp for input. Amp is powered up and working fine- connect sub to amp, sound seems distorted, sounds like **** basically.
    Sub works fine when hooked up to the rear speaker wire by itself, but obviously underpowered (did this just to make sure sub wasn't blown).
    Can anyone offer advice?
    Sam
    AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
    I think you do have the monsoon amp in your car. I had the same problem when I first installed my amp (I didn't think I had the monsoon amp either). Check behind your spare tire to make sure you really don't have the monsoon amp there. I ended up running new speaker wire from the amp to each speaker.
    <a href=\"http://www.cardomain.com/id/edogg_127\" target=\"_blank\">1999 red 38000 Camaro</a><br />Leaking rear main seal (not really a mod though)
      So you ended up not using the amp you bought?
        Sorry that wasn't clear. I ran wires from my new amp to each speaker. Everything sounded perfect after that.
          I don't have the Monsoon amp. Blah.
            Someone help...
            just tried a different amp, a Rockford Fosgate- same results.
            [ June 01, 2003: Message edited by: xjarayax ]</p>
              Uh... whats LOC?
              <b>Black 1996 3.8L Firebird A4</b><br />--------------------------<br />Custom CAI, Flowmaster Dual Exhaust, 160 Deg Thermo, BMR ShockTower Brace<br />JVC mp3 HU, two 12\" Infinity Kappa Perfects, Infinity 6.5\" components, JBL 600.1 & 80.4 amps <br /><a href=\"http://community.webshots.com/album/479229363CPbPiz\" target=\"_blank\">Pics</a>
                The problem is ur input not ur amp bro- I did this setup for a while only I used the right rear speaker for input. Got way distored sound, changed to a deck with preouts ( RCA cable ) and bam, qulity like no other . I have a JL 12 w6v2.
                97 Special Edition Bird , Short bus stlye special
                  Yeah I figured your HU didnt have an LCA output. LCAs make it so much easier.
                    Can't afford it- actually I think the sub might be blown.
                    Did you use an LOC and it still didn't work? This is discouraging.
                    [ June 02, 2003: Message edited by: xjarayax ]</p>
