I've looked everywhere for this information and I think I must just be doing something wrong. I removed the radio bezel, unscrewed the screws and I can pull the head unit part way out but not all the way. I can feel what I assume is the wiring holding it back. Is there somewhere else I have to unscrew in order to get to the wiring in the back?
Real basic - firebird radio removal
unplug that one a the unit will come out moreheaders, high flow cat, slp loudmouth
powerdyne supercharger 6psi
GT2 cam. all done by myself :banana:
Hell yea
http://memimage.cardomain.net/member...50_80_full.jpg
see where I have the grey wire running behind the console? reach behind there and up and you should be able to get it. if you get in the floorboard and look you should be able to see what you are doing. on mine all the wires were split into 2 bundled groups and had some kind of divider in the middle that I had to lift the wires over to get it to come out far enought to do anything.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
So I have to unscrew it by opening up the glove box and doing so from there?
also you can get to the cable that andrew mention from the same locationheaders, high flow cat, slp loudmouth
Hell yea
Just pull really hard, thats what I did. The antenna plug is in very hard, will take some strength to get that out. But don't be shy, you won't break anything (worth a lot ;) ).<b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
Thanks, I got it out now but the thing is after putting it back in, my LED display is very very dark. It almost looks like it's not even on but you can barely make it out. WHen I turn on my lights, the leds behind the buttons come up alright and the radio still works fine but just the digital display is very very dark. What did I do?
I checked and all the connections are in solid and tight.
I checked and all the connections are in solid and tight.headers, high flow cat, slp loudmouth
Hell yea
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...22 hours ago
