question about manual fan switch. - FirebirdV6.com/CamaroV6.com Message Board
  • question about manual fan switch.
    I had a question about a manual fan switch. I had an idea, was going to see if anyone had tryed. I did a search, but of course nothing came up. When you wire a manula fan switch in, the norm is to just run a wire from the positive cable, all the way to the dash, then all the way back to the fan, to turn the fan on. I had the setup in my old firebird, and when I looked at it, I think my battery had somewhere abouts 12.2 volts at the positive terminal, and then right before hitting the fan, after running through that long @ss wire and the switch, it was at 10.2 volts. So, a 2 volt drop. I was thinking of a new way. Could I get a ford starter solenoid. And then run a diagram similar to this:
    *Picture of schematic*
    My main concern is that, these solenoids obviously only have to work for a couple of seconds, then when the engine is started they have completed there job, and by being open all the time, I think in a short amount of time, it would burn out. Just wondering if anyone has done this. It was just an idea, to reduce voltage drop. TIA for replies. :D
    If I'm not mistaken the fan switch is really just a ground. All it does is when you flip the switch it grounds the circuit and turns on the fan. I don't know a whole lot about electronics so I very well may be wrong, but that's what it seems like to me. And you don't have to run a wire to the dash then back, all you need is one wire to your switch.
    <a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood Blues
      what he said...
      you jsut ground the high and low wires in the harness over the passenger side wheel(That group of like 3 harnesses)
        the wires that fan switch install guides make reference (blue and green i think) to are already going to relays. its easier for the pcm to switch relays than the fans directly.
          Oh ok. Thanks guys. I totally was mistaken, and thought the switch had to be on the hot side of the whole circuit. That makes since to have a switch on the ground side. Thanks for the help. ;)
            yeap, ground side is easier, no need for heavy duty 630/40/50 amp relays.
            as long as you don't mind hacking into your wiring harness thats the easiest way, just throw a ground to it, the V6's don't seem to throw ses lights on the simple grounding method.
            Ryan
            1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
