ok this may be a stupid question but ive searched the site and can't find an answer, what wire out the of the stock deck runs to the REM input in the amp? really tired and no results in searching
first time installing stereo and can't figure out this problem. please help.
\"Knowledge is Power\"<br />There\'s no Replacement for Displacment.<p>Pro 5.0 Short Shifter, RK Sport Dual Exhaust, Fast Toys Cold Air Intake, Hotchkis Strut Tower Brace, K&N Air Filter
there are plenty of other wires to use. test a few to make sure you get power when key is on, and no power when key is off
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
There is no REM wire on the stock head unit. The amp turns on when it senses a signal from the speaker wires.
Like Tyler suggested, use the wire that activates the power antenna, the Pink wire. Or you could use the Yellow wire on the back of the head unit as well. The Yellow wire switches on and off with your ignition.
