Eu-700 Install Guide - FirebirdV6.com/CamaroV6.com Message Board
  • Eu-700 Install Guide
    Tool & Materials:
    1/2 in wood used to make the spacers
    Jig saw to make rings
    Cutting tool to make cuts for the voice coils to fit (dremel, jig saw, whatever works)
    Wire
    Sound Deadener (optional)
    Pliers
    Drill
    1. First thing you have to do is remove the sail panels. To do this all you have the do is unscrew the 1 screw by the door and use a screw driver to pull the clip out of the little hanger. Then it just pops off, it’s held on by Velcro.
    2. Now that you have the speaker out, you can "seal" the space up or just leave it like it is. I chose to seal it up a little bit. I just cut chunks of sound deadener (edead v1) and covered the big holes with it. You might want to run a ring of deadener on. The outside where the ring with sit on the body to prevent vibration.
    Optional steps to prevent rattles:
    3. Notice this wire, the plastic clips that hold it on are very loose. These can and will cause rattles.
    4. Use some pliers to wiggle them out and cut at the line, or just that the hold plastic ring off.
    5. Cover the holes on the body with a little square of sound deadener. This will keep this wire from vibrating on the body.
    6. Use a strip of sound deadener to hold the wire in its stock location.
    End of optional Steps
    7. Cut out 2 indents in the body to fit the voice coils in. I got away with doing one big one. After you done test fit to make sure you can fit them in and out easy. I cut mine on the side, but the coils are one the top and bottom of the speaker when the eD logo is horizontal. So I just put them in and twisted them.
    8. Cut your wooden rings out. I used the speaker cover that comes with them, to protect them during shipping as the template. Don’t forget to make the indents for the coils.
    Optional Step
    9. After you do that you can cover it in deadener to help seal it up and prevent rattles.
    10. Test fit your ring, and test fit the speaker. Drill and screw the ring on. Then screw the speaker on.
    Use this stage to trim up and make sure the voice coils can fit.
    11. Take your ring off and use some kind of sealant on the back of it. I use liquid nails.
    12. Run your speaker wire and hook up the speaker. I just drilled a hole next to the ring to run it.
    13. Slide it and secure it.
    That’s it, not much too it. I also cut a little off of the sail panel’s cuz they were rattling off the outer ring of the speaker.
    The grills still fit but it is very tight.
      THANKS SOO MUCH i am going to order these next week, along with there components and 40 sg feet of edead!!! [img]graemlins/rock.gif[/img]
        you getting the 6000's or the 6500's?
        either wya it will sound sick!
        are you going to run them off an amp? what kind?
          im getting the 6000's 6500's are a lil high and i think 600's will be plenty!! a audiobahn 4004t!
            i agree, the 6500's are pricey. the 6000's are great! that amp will match up well.
