1993 Firebird Schematics/Wiring - FirebirdV6.com/CamaroV6.com Message Board
  • 1993 Firebird Schematics/Wiring
    I want to install alarm system to my car and i need to know my car wiring. Where i can find those? my car is 1993 firebird.
    how good are you at wiring? Ever done something like this before?
    Chances are you havent, and the alarm is only as good as the install. If youve never done anything like this i would just leave it alone because its TOO easy to burn something or cross a wire.
    Alarms use negative triggers for door locks and other things, in which you have to know what your doing.
      First, I must agree with CAMAROWIDBASS. It's not easy task. Give the pro 50 bucks and let him/her do it.
      But.....
      12 volt - Red*
      Starter - Yellow*
      Ignition - Pink*
      Acc (heater blower)- Orange*
      Acc - Brown*
      * heavy gauges wires in ignition switch harness located under the dash by the steering column
      Passlock wires - 2 small guage wires in oranging sheathing near ignition harness
      Brake wire - Light Blue(+) - at brake switch or wire harness running by the door sill
      Reverse wire - light green wire (+) in white harness in passenger kickpanel)
      Tach - white wire in lower harness of PCM. Pin 35 for 98 and Pin 10 for 99-up
      Trunk release - Black/white at switch
      Headlights - Yellow(+) - at headlight switch
      Parking lights - Brown(+) - at headlight switch
      Horn - black(-) - steering column harness
      VSS (vehicle speed sense wire) - Green/white - Radio harness on camaros...at cruise control module on Firebirds. (normally used for navigation systems)
      Factory arm - (+) - Gray at BCM
      Factory disarm - (+) - Tan at BCM
      Door Lock - Red/black (-) at BCM
      Door Unlock - Orange/Black (-) BCM
      Door/Trunk trigger - White (-) at BCM
      **You'll have to wire the alarm for domelight supervision so that the BCM "wakes" back up**
      Drivers window up - Blue*
      Drivers window down - Brown*
      Passenger window up - Light Blue*
      Passenger window down - Tan*
      *located in the drivers door
      PCM is the computer in the engine compartment near the windshield on the passenger side.
      BCM is located in the passenger kickpanel.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        Well.. i never before install car alarm but i am electronic engineer so i have little experience.. and i have friend who is install same alarm system that i have in his car.. so i use him help too..
        thanx a lot to helping.
