Can i hook up subs and an amp to the stock head unit of a 96 firebird??
subwoofers?????????
<blockquote>quote:</font><hr>Originally posted by shortdog273:
You might transfer your message to the stereo forum.<hr></blockquote>
Nahh, I'll take care of it ;)2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
What do you do once you get the LOC?
me and my friend were thinking about doing this on his '91 maxima, with a bose sound system....
his cousin gave him a free 12", not sure of brand, he never told me
thx in advanceIt\'s not forced induction if she takes it willingly
The LOC has a few wires to tap into. You should probably use the rear channel speaker lines from that came stock. This LOC simply makes that signal into one usable by the amps. It takes regular speaker wire, and gives you RCA outputs. Easy to hook up the LOC towards the rear of the car where the amp will be so you don't have to run wires from to back for the LOC.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Crossover won't make lower frequencies, it just lets them be played. But if your sub, enclosure, and amp are not all capable of certain frequencies, then a crossover won't help. Certain box designs don't play as deep, period. Certain subs have limitations. Other amps don't have enough power to push the sub and keep it in control at lower frequencies. Your set-up is only as good as its worst component. You might have to upgrade, but try working the gains and crossover settings on your amps for now.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
