Figured a little more about my electrical problem still need help though - FirebirdV6.com/CamaroV6.com Message Board
  • Figured a little more about my electrical problem still need help though
    ok so today i busted out the multimeter. i was talking to my brother and he said try disconnecting the - on the bat and using the + on the meter on a chassis ground, then use the - on the bat terminal. i am getting a voltage reading. it started at around 10v and then slowly went to 11.9(i stopped after that). the battery was at 12.8 and by time i was done it was at 12.2. i disconncected all of my stereo stuff and lighting while i did this.
    so obviously i have a short somewhere on the stock harness. i dont understand when the voltage would start out low and then slowly go up any ideas? i also dont get why it wouldnt just match the voltage of the battery. anyone have a good idea of where to start looking or a good way to find a short?
    does anyone know if using a test light and checking the fuse box would help?
    also could the voltage regulator be the problem? where is it located? is this a common problem? any ideas?
    [ December 14, 2005, 03:08 PM: Message edited by: articacid ]
      i had a wiring short on my firebird causing the batt to drain, i disconnected the - cable hooked the wire to the cable from the test light and had someone old the probe of the test light to the neg post and it lit up. I then pulled 1 fuse at a time until it went off to narrow down what circuit it was. For me it was the accy circuit. Turned out to be a problem with the door lock relay
      1990 Firebird 3.1 T-Tops<br />Flowmaster exhaust<br />Kenwood MP 825 Deck<br />4\" Rockfords w/ tweet in dash plate<br />3 Way 6x9 Rockords in rear sails<br />1970 Camaro 350
        when i tested it i thought i had everything off, but i forgot about one thing, the alarm. which explains the voltage slowly increasing and never reaching the full 12v.
        its beginning to look like theres a very good chance its the alt. maybe it wasnt discharging, it might just not have been charging very much at all.
        its still putting out voltage but in a very goofy way. it actually was howling the other day when i started it up. i ordered a 180 amp alt from 4alterstart.com should be here friday and hopefully it will solve my problem.
