Hood water drain - FirebirdV6.com/CamaroV6.com Message Board
Hood water drain
This topic is closed.
  • Hood water drain
    On 98+ firebirds, when you poor water or rain on the windshield, its falls the the plastic thing then drains off. But just under that where the grill things are, when water gets there, it drains down to the sides and falls inside under the hood. On the PCM?! Is it ok for that to get wet?
    I found this trying to install a power wire through the grommet under the PCM and I poored water to make sure if i put the wire through, no water would leak into the car through the grommet.
    I kinda posted this on LS1 when the forum was down.
    http://www.ls1.com/forums/showthread...threadid=43658
    So i guess my question is, is it ok for the PCM to get all wet like that? and For people that had 'leaks' on passenger floor, was it from that grommet?
    Thanks
    [ February 13, 2002: Message edited by: TheRealWave ]</p>
    2002 Black FireBird M5 2-5-02<br />Red BMR strut bar<br />Dynomax Super Turbo muffler with FastToys.com tips.<br />4 Coats of Zaino - Better every time<p>Need to post pictures? Do it <a href=\"http://www.thenebula.com/carpics/\" target=\"_blank\">here</a>. its <b>easy</b> and <b>free</b>.<br />Change your own oil. <a href=\"http://www.thenebula.com/firebird/oil/\" target=\"_blank\">click here</a>.
    That's the place where I run all of my stuff through. No leaks for me...yet.
    Jason
    2001 Yamaha FZ1<br />1996 Camaro M5 Sexy Black<br />\'99 Vette Wheels with Nittos<br />1LE Swaybars/Endlinks<br />Bests: R/T .659, 60\' 2.179, 1/8 9.957, 1/4 15.6, MPH 87.26<br /><a href=\"http://www.camaroman.cz28.com\" target=\"_blank\">My New Website</a>
      Moving to General Tech.....
      <b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
